I have the ARCHD.SHX, ARCHF.SHX, ARCHS.SHX, ARCHT.SHX and several other .SHX fonts in my LT 2017 font folder, however, I don't see them as font choices when placing text. Am I missing something?
If you received the drawing from someone else and they did not use eTransmit, this is a common issue. Run the STYLE command and select the textstyle in question. Now look at the Font Name selection. Is there a yellow shield near the font name as shown below? If so, you are missing that font!
MTEXT or any command that uses text. The text editor has a drop down that shows all available fonts. TTF and shx. However, many fonts in the LT font folder do not appear.
HI @CalypsoArt,
It sounds like you have placed these fonts in your default SHX location. Have you tried adding them to a new folder and adding that folder to your support path?
If you like, you can zip the fonts and attach them to a post so I can see if I can duplicate this behavior. Sometimes, if a font is corrupt, then it also won't show up.
I am happy to take a look for you.
I tried as you suggested. Made a folder of all the .shx fonts that don't appear and added the path. Restarted AC and still no go. I've attached the zip file.
Hi @CalypsoArt,
I am looking at the font files you are trying to use and the file size is only 1 or 2K. Without grabbing a utility to examine them I would say they are damaged and contain little if any information.
Is it possible to obtain new copies?
I don't remember because it was a while back, but I believe I got some of them from here. https://www.cadcorner.ca/textstyles.php
I tried one and it did not work. Perhaps the fonts are corrupted.
The Font Name dropdown in the STYLE command, and the dropdown in MTEXT, show the same available shx and .ttf fonts.
Following up were you able to find a solution or a suitable workaround?
Post back with any new updates.
Please select Accept as Solution if my post or any other post in this thread resolves your issue. Thanks!
