Hello dear AutoCAD users and experts,
"Shift + Space" - Selection cycling - Not Working
The selection of objects behind other objects doesn´t work anymore. I believe I either pressed the wrong buttons and deactivated something or it either changed after a recent update. Could you give me some insight in what could be the issue?
Thank you very much in advance.
Solved by cadffm. Go to Solution.
@infoX8V73 schrieb:
Now it shows the first preview of the object under the hatch (that´s my case),
As generally rule: If you have trouble with something, you should test things with simple object or situations.
If that work, go to the more special objects/situations.
Test it again with 3 crossing lines, no hatch.
Please share a Screenshot of your whole program screen, or much better: Share a *.svf file!
Command SYSVDLG (if ExpressTools are installed - what should ever be the case, except you are using LT)
saveall
Sebastian
