'Settings transfer' when switching from monthly to yearly subscription
My AutoCAD LT 2019 is refusing to fully load.  It freezes at the opening screen.  I am currently on a monthly subscription and now may be a good time to switch to a yearly subscription.  My question is "Will my settings transfer to the yearly subscription or do I need to go thru that again.
MarkGunnAutodesk
@Anonymous  - I'm asking one of our business side community managers if they know the answer on this one. I'll try to get back soon.
amanda.k
Hi rstd04, and welcome to the community!
I've consulted with some of our great technical support specialists, and they assured me that the settings for the program are stored in your user profile on your computer, and just changing the subscription type (NOT reinstalling the program, just the subscription type) won't reset your settings. Nothing should change on the software side at all - just on our backend side. 🙂
I hope this helps! If not, let me know in a reply to this message and I'll get you an answer ASAP.
Thanks!
Amanda
Amanda Pruyn
Principal Community Liaison Manager
natasha.l
Hello @Anonymous,
Just to clarify you would like to transfer your application settings, correct?
There is a migration utility it is installed with AutoCAD. It runs automatically after installation. To run it at any time, it is next to AutoCAD in the Windows Start menu:
  • Windows 10 and 8.1Start > AutoCAD 20xx > Migrate From a Previous Release
  • Windows 7 and XPStart > All Programs > Autodesk > AutoCAD 20xx > Migrate Custom Settings > Migrate From a Previous Release
The migration utility migrates settings between two versions of the same AutoCAD product in the same language. Also, both versions must be installed currently on the same machine.
How to migrate settings from an older version of AutoCAD to a newer one
For versions of AutoCAD that do not have the utilities, see How to manually transfer AutoCAD user settings.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Thanks everyone,
Because AutoCAD 2019 (monthly) was non-functional I decided to procede with loading AutoCAD 2020 (yearly subscription).  It went flawlessly and seemed to have picked up most of my settings . . enough to be comfortable with.  I tend to run AutoCAD without the command prompt now as it seems to not agree with the command sequences that I have in my mind.  I've been using AutoCAD since 1988 and kind of set in my ways.
Thanks again !
natasha.l
Hello @Anonymous,
Thank you for returning to let us know that the suggestions offered helped you resolve this issue.
Please remember next time to "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
We hope you continue to support the community by contributing! 😀
Thank you Natasha,  I went ahead and loaded AutoCAD LT 2020 and all went fine.
Darryl
