Selecting a block has a larger version of the block too
oliver_bushNN3AR
Observer Observer
oliver_bushNN3AR
Observer
Observer
Hi!
I have a recuring issue where If i select a block it has a larger version of the block many times its size in the model space.
They are not counted in the block count function
If i select multiple blocks it happens multipile times
 Thank you for your help in advance
h_s_walker
That is because it is an annotative block and it is showing the block at all the scales which it has in it.
At the command line type SELECTIONANNODISPLAY. Change the value to 0. See the link below for an explanation.
AutoCAD 2022 Help | SELECTIONANNODISPLAY (System Variable) | Autodesk
Howard Walker
Left Handed and Proud
