Selected elements not shown in dashed lines + strange mouse performance
KMYD
Message 1 of 9
KMYD
Since I upgraded my AutoCAD last year I started having problems with my shoulder due to the mouse acting funny when selecting elements (it's not as fluid as it used to be). I did all the operations suggested by Autodesk but this didn't solve the problem. I also changed the selection from highlighted to dashed but the selected elements are not shown as dashed. Any ideas?
Replies (8)
Message 2 of 9
pendean
Community Legend
Community Legend
>>>... mouse acting funny when selecting elements (it's not as fluid as it used to be)...<<<
Sadly this means nothing to anyone over here: can you elaborate further?
Message 3 of 9
KMYD
It's hard to explain but when I try to select something and the mouse gets close to the object it becomes slower and almost stops just before so takes some effort to select anything.
Message 4 of 9
RobDraw
Did you try a different mouse?
Rob
Message 5 of 9
KMYD
Yes, I did. the same problem
Message 6 of 9
pendean
Community Legend
Community Legend
Do you need to turn off any running osnaps first?
Do you need to scroll/zoom in a lot closer to make a selection?
Do you need to hit that F9 button to toggle off SNAP command and its setting that only appear while you are running a command?
Message 7 of 9
KMYD
I don't use F9 at all. It's off all the time. I think I solved the problem of the mouse.
Any ideas about the selected objects displayed in a dashed line?
Message 8 of 9
pendean
Community Legend
Community Legend
So what was the fix?
Your video card choking perhaps: turn off hardware acceleration to see if that helps.
Or do you mean this https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-c...
Message 9 of 9
KMYD
I don't know at the end. I changed few settings over few days. It wasn't the video card.
Thank you for the link. It works now when HIGHLIGHT is set to 0.
