AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Select muliple dimensions and Autocad automatically sums them and gives a total
2 REPLIES 2
paul9ZMBV
500 Views, 2 Replies
Surely there has to be a way of selecting muliple dimensions and Autocad automatically sums them and gives a total.
I find myself having to type into a calculator various dimensions and adding up manually to find out the total sum.
Any ideas i understand lisps cant be used on LT (not that i would know how to write or add a lips)
Any advice much appreciated.
2 REPLIES 2
cadffm
in reply to: paul9ZMBV
"Surely there has to be "
Surely not.
For this goal you should use another program, sorry.
Power-LT-Users can set up a workflow and automation to get the sum by LIST command and an additional external program,
but this is nothing to learn in days (or are you able to program your own tools ? Excel vba would be enough..
Sebastian
pendean
If this is a dire business need then it is time for you to subscribe to full AutoCAD to take advantage of it's programming abilities like this https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/add-dimensions-total/td-p/7608221
if this is a one off wishlist, you spend more time finding a fix instead of using a calculator: unless all of these dimensions are in a single row, end to end, in which case a simple DIMCONTINUE from last to first is all you need to do to get a total.
Technology Administrators
