AutoCAD LT Forum
Script Switching to next layout
7 REPLIES 7
Message 1 of 8
1420 Views, 7 Replies
Hi dear,
I have more then 100 drawing to update the attribute, i write script to open the drawing to update the attribute
but doesn't update all layout(each drawing have three layout).
My question is:
* How to switching to next layout in the script.
If i press button [Control+Pagedown] bring to next layout but i dont know how to write in the script.
thanks
Siva
7 REPLIES 7
Message 2 of 8
(setvar "ctab" "layoutname1") will make the tab with "layoutname1"
current e.g. (setvar "ctab" "Elevations")
George Drayton CD-CAD Ltd Christchurch New Zealand
Message 3 of 8
OOps no lisp in LT - use the CTAB command and enter a layout name
e.g.
Command: ctab
Enter new value for CTAB <"Model">: layout1
keyboard or a script file>
Regenerating layout.
Regenerating model.
Message 4 of 8
Possible to do without layout name bec. i have different name each layout and each drawings.
Thanks George
Siva
Message 5 of 8
Nope, script files are exact/specific, they emulate what you would type at
the command line as a command/sub-command sequence (not all keyboard
shortcuts work).
HELP explains what keyboard shortcuts you can use in macros (some work in
Script files but not all) at
AutoCAD LT Customization Guide > Customize the User Interface > Create
Macros > Use Special Control Characters in Macros....
Dean Saadallah
http://LTisACAD.blogspot.com
Message 6 of 8
thanks for your help.
I wrote lisp to update the attribute each layouts.
thanks.
siva
Message 7 of 8
Quiet useful CTAB command.
We have Autocad 2004 but need to share each other.
thanks.
siva
Message 8 of 8
If you have access to full AutoCAD you can cycle through layouts without
knowing their names. The lisp fubction (layoutlist) return a list with
the names of the layouts which you can"select" one at a time with say
the (nth)function to make that layout active and then do the relevent
editing
Technology Administrators
