AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Script Printing
1 REPLY 1
677 Views, 1 Reply
Script Printing
Hi guys and thanks in advance. Can anyone provide me with a good script to easily print my files. I have over 800 drawing I want to print where each is defined by an outer rectangle as shown in the attached image. Knowing that the rectangles are equally spaced and their co-ordination is known. What is a good script to run to help me print them quickly?
Thanks in advance.
Tags (2)
1 REPLY 1
pendean
There is nothing built in to do that: you appear to have opted to disregard using Layouts in AutoCAD/LT which would have simplified your current need to batch plot all these titleblocks using PUBLISH command.
You will need to take the time to create a unique VIEW for each titleblock you need to plot in each DWG file, and spend hours writing a script file that captures each, or spend hours creating a layout for each titleblock then PUBLISH then all in minutes.
Or you need to start subscribing to full AutoCAD and look for an add-in to use from the LISP forum that will take the bite out of all those hours of setup.
Which can your wallet and schedule tolerate?
Technology Administrators
