AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Screen Issues
3 REPLIES 3
301 Views, 3 Replies
Screen Issues
Drawing screens jumps:  The drawing screens gets bigger/small, bigger/smaller...Why?  I've rebooted and no good, problem still exists. Makes drawing unbearable. What's the problem & fix?
3 REPLIES 3
Charles_Shade
Welcome to the Autodesk Forums!
Are you referring to Zoom moving closer and further away unexpectedly?
Model or Paperspace?
SWAG - Time to replace the mouse perhaps?
in reply to: Charles_Shade
Model space.
The four bars at the bottom of the drawing screen (command, status, the
screen slide & regenerating model) will move/jump the screen up and down
when the cursor is resting near an object like text. My solution to the
problem was to simply copy drawing and paste it into file that I knew didn't
have the issue.
Thanks for the response.
pendean
LT version you use is (why do we have to ask)? Have you installed all the patches and updates for it? I'd point you to the location to get them, but I have no idea what version you are using or if you've done any of it.
Windows version in use is? If WIn10, you are out of luck for help and need to roll back to your older Windows version.
Technology Administrators
