scattered text when opened in older version of autocad....
Hello all,
We have ran into a very annoying problem in our firm. I use Autocad LT 2012, and a few others do as well. Some people use autocad 2000 (full version). We have ran into the problem of text being scattered, as well as leaders. The problem only exists if someone using the 2012 LT version creates the text. The problem is enhanced if a leader was created with text.
When opened in the 2000 version of Autocad, the text sometimes changes its justification, and if a leader was used the text sometimes flips to the other side of the leader, and the leader cannot be adjusted, or in most cases, not moved at all.
If I open up the same file that appears to be messed up in a 2012 LT version, the text and leaders look/work just fine.
Is there a simple fix to this problem? Any solutions or suggestions are much appreciated! Thank you in advance for your advice (if any!)
-Matt
