This may be a very niche request. But I have projects I work on at work that require me to scale only certain parts of drawings. I am relatively new to AutoCAD and come from a solid works back ground. In solid works it is possible to lock certain dimensions or locations of objects in relation to another. I am struggling to find a way to do this in AutoCAD.
The goal for me would be to be able to open a parent file, change a couple of dimensions that we need to be different and have the rest of the drawing follow the guidelines set.
In the drawing you can see that they are simply scaled drawings of the same thing. however where some sizes change others remain. The smallest squares remain the same size and their positions remained the same relative to the center points of the outer rectangle. This is the case for the long rectangles as well, with the exception that their width remains the same but the height changes.
I apologize for the awful explanation, if I can clarify more please let me know. Thank you.
Solved by pendean. Go to Solution.
@adJQ9S6 wrote:..come from a solid works back ground. In solid works it is possible to lock certain dimensions or locations of objects in relation to another. I am struggling to find a way to do this in AutoCAD...
You are posting in, and I assume you are using the software this forum support, the AutoCADLT forum: in this variant, Parametric Controls (aka what you used in SolidWorks) are not an option to create to use, but if someone with full AutoCAD can set that up for you in each and every DWG file, you can at least use that ability in LT.
If creating and using Parametric Constraints this is a dire business need, you will need to abandon your LT subscription and start a new subscription for full AutoCAD (+/- 4x the annual cost) to do what you want https://help.autodesk.com/view/ACD/2025/ENU/?guid=GUID-899E008D-B422-4DF2-AC8D-1A4F5701ED4E
BTW, the comparable SolidWorks software at Autodesk would be Inventor or Fusion. if you do that type of work, as AutoCADLT is just a general CAD type program, smarter that paper drafting but not best for SolidWorks type of automated output.
Back to your post: in LT, explore SCALE command, here is an easy to follow online tutorial
That's kind of what I have been figuring out. A lot of the things my company is asking me to do will require me to get the full program. I currently only need the drafting abilities not the full 3d which is why I use AutoCAD.
Thank you fo
