AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Scales missing from base drawing
3 REPLIES 3
mbetGEGZX
615 Views, 3 Replies
Was putting the finishing touches on a drawing that will be used as a template and found the architectural scales were available and engineering, ratio style scales missing. Need them both and want to know the easiest way of how to add get the engineering style scales back into drawing.
3 REPLIES 3
steven-g
in reply to: mbetGEGZX
Find an existing drawing that has those scales and add them back to a new blank file created with your template, then resave this file as a template.
cadffm
Do you now for what these scales are?
The simplest way, Command: ScaleListEdit
If not edited/customized the program-standard scale list before, you can use RESET.
Sebastian
mbetGEGZX
in reply to: steven-g
That's probably the easiest way. Don't know what happened that some would not show up.
Technology Administrators
