saveall command missing
Message 1 of 14
I just upgraded to Autocad LT 2019 and can't use SAVEALL COMMAND, is there any other way to save multiple drawings at the same time?
Replies (13)
Message 2 of 14
pendean
Community Legend
Community Legend
What else doesn't work, how about CLOSEALL?
Did you use the MIGRATION tool to move content from a much older AutoCAD version?
Do you have a 3rd party add-on?
Have you reset R2019 to see if it comes back?
Have you tried a reinstall yet?
SAVEALL works just fine in R2019 in our office.
Message 3 of 14
What else doesn't work, how about CLOSEALL? yes.
Did you use the MIGRATION tool to move content from a much older AutoCAD version? no. I was using 2000
Do you have a 3rd party add-on? no.
Have you reset R2019 to see if it comes back? yes.
Have you tried a reinstall yet? not yet
Message 4 of 14
pendean
Community Legend
Community Legend
I suggest a reinstall, answer yes when prompted to replace files: let us know what you find.
Message 5 of 14
TheCADnoob
What is happening when you initiate the command?
CADnoob
Message 6 of 14
unknown command
Message 7 of 14
TheCADnoob
Message 8 of 14
unknown command.
Message 9 of 14
Thank you.
Its funny that LT can't do saveall but it does close all.
Message 10 of 14
TheCADnoob
Look like it made the leap into LT around 2009
https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/sfdcarticles/sfdcarticles/Expre...
Its that odd line between LT and full AutoCAD
CADnoob
Message 11 of 14
cadffm
>> "Its funny that LT can't do saveall "
AutoCAD (fullversion) also not, with a complete standard installation 😉
EXPRESSTOOLS (Express Tool)
http://help.autodesk.com/view/ACD/2019/ENU/?guid=GUID-87BF0045-6446-48C6-8413-DE025596396E
About AutoCAD Express Tools
http://help.autodesk.com/view/ACD/2019/ENU/?guid=GUID-E0F8792C-8698-4307-992B-FE53952F47D2
CLOSEALL (native command in ACAD+LT, since 2009)
http://help.autodesk.com/view/ACDLT/2019/ENU/?guid=GUID-E5BAAD2B-C4E5-4DF0-A483-95C8AD89BE91
Sebastian
Message 12 of 14
pendean
Community Legend
Community Legend
Ahh, I missed the part that you were using LT, my apologies. I'll ask the moderator to move you to the correct forum.
SAVEALL and CLOSEALL in LT are only available when you right-click on a FileTab but no where else, not even as typed commands. Try it now.
Message 13 of 14
excellent.
thank you.
Message 14 of 14
pascua_marvey_rose
Community Visitor
Community Visitor
SAVEALL in AutoCAD LT 2024 is unknown
but you can right click on any tab open then you can see Save All, also u can do different commands as you can see in the pic.
I hope this helps.🙂
