save as command not working
stcroixrds
Message 1 of 12
stcroixrds
Hi all,
acad lt 2014
windows 7 pro
Today I opened one of my acad lt 2014 drawings and immediately tried to do a "save as" to rename it in order to keep the original pure...so to speak.
I activated the save as command by using the file tab and selecting save as and then choosing drawing. Normal method, I have done it thousands of times.
Today it does not work.
The save as command shows up on the command line like you would expect, but no dialog box appears for me to select a location and enter the new name. It just sits like that until I hit esc at which point I am able to work on the opened file like normal and save that file like normal.
Also, if I start a new drawing from scratch (drawing 1 by default) and try to save or save as it will also not work.
Any Ideas what is happening?
Paul
Replies (11)
Message 2 of 12
h_s_walker
It sounds as if your dialog boxes have been switched off.
At the command line type in FILEDIA and make sure it is 1.
Howard Walker
Left Handed and Proud
Message 3 of 12
rkmcswain
If you think the dialog is being suppressed, type in FILEDIA and set it to 1.
If you think the dialog is opening, but it's "off your screen", see this:
Message 4 of 12
stcroixrds
Thanks for the quick reply. Unfortionately that did not work. Was already set correctly and all other dialog boxes working as expected.
Message 5 of 12
stcroixrds
The off screen thing could be it...I usualy work with two monitors and I am currently just using the laptop screen. I will hook up to my second monitor and see if it is hiding over there.
will let you know,
thanks
Message 6 of 12
stcroixrds
That was it!
Hooked up secondary monitor and there it was.
Thanks!
Message 7 of 12
rkmcswain
When you say it requires you to press ESC to continue, that usually means the dialog is "off the screen".
You can test this even when your dialog is visible. Launch a model dialog and try to do anything interactive EXCEPT with the dialog. You can't until you close the dialog (which pressing ESC does).
Message 8 of 12
pendean
Community Legend
Community Legend
Don't unhook the second monitor again before your test all the other popup commands you use often.
Message 9 of 12
899361679
Community Visitor
Community Visitor
I know this chain is super old now but I had this problem and your "FILEDIA set to 1" solution worked! I had never had that happen before so just out of curiosity what would have caused the dialog box to become suppressed like that? Thank you for this information even 9 years later!
Message 10 of 12
pendean
Community Legend
Community Legend
@899361679 wrote:
...so just out of curiosity what would have caused the dialog box to become suppressed like that?...
One of your custom LISP or tools (or add-ins or 3rd party add-on) did that, or another user did it for you, not much you can avoid if you find out what that is.
AutoCAD has a tool called SYSVARMONITOR, start it up, you'll see this variable in there (stock install unless you removed all the entries in it): activate it and have it ready to help you catch changes to this and a few other key variables that you feel you must have on (or off).
HTH
Message 11 of 12
ianmockford1962
Community Visitor
Community Visitor
spot on
Message 12 of 12
pkumarYD79F
Community Visitor
Community Visitor
its work, thanks so much
