AutoCAD LT Forum
S-DIM
7 REPLIES 7
Message 1 of 8
cindy
524 Views, 7 Replies
S-DIM
Does anyone know what happen to dimension style? I got this "S-DIM" layer everytime I copy object from others it will appear "S-DIM" layer after tagging with dimension. S-DIM is not the dimension layer created by me. It will automatically goes to "S-DIM" layer for all the dimension. Anyone knows how to get rid of this? Or remove it from the program? Thanks
Labels (1)
7 REPLIES 7
Message 2 of 8
paullimapa
in reply to: cindy
does LT have this variable called DIMLAYER that perhaps your drawing template has set your dimension layer for you?
Dimensions are not created on the current layer in AutoCAD (autodesk.com)
Paul Li
IT Specialist
@The Office
Message 3 of 8
cindy
in reply to: paullimapa
Thanks for the reply; the drawing was start from scratch. I didn't create any S-DIM in layer properties. Just noticed that when I copy object from previous project, my current drawing will appear S-DIM for dimension. Even though the previous project also dont have that S-DIM in layer properties. Just wonder will Autodesk can remove this function?
Message 4 of 8
paullimapa
in reply to: cindy
Curious when you start a new drawing and then draw a new dimension what layer does that new dimension end up on?
Paul Li
IT Specialist
@The Office
Message 5 of 8
cindy
new drawing with new dimension start with "0" layer. but if I copy object from pervious project, the dimension will start with "S-DIM".
Message 6 of 8
paullimapa
in reply to: cindy
And that dimension copied from the old project…what was the layer it was on in that old project drawing?
Paul Li
IT Specialist
@The Office
Message 7 of 8
cindy
in reply to: cindy
My colleague just solved my problem! 🙂 She change the setting to this: Use Current; was S-DIM. So from there onwards my dimension will follow to which i selected.
Message 8 of 8
paullimapa
in reply to: cindy
exactly my solution in my initial reply back in message #2:
https://forums.autodesk.com/t5/autocad-lt-forum/s-dim/m-p/12462013/highlight/true#M203541
Paul Li
IT Specialist
@The Office
Technology Administrators
