AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Rotated UCS on Startup
7 REPLIES 7
Message 1 of 8
1449 Views, 7 Replies
I had a new and clean install of AutoCAD 2016 LT and the program started normally with the UCS facing upward as usual. I created an AutoCAD 360 account and it sync'd my settings. I then opened a drawing which had a rotated UCS, made edits, and closed the file. Every time I now open AutoCAD, it starts the program with a rotated UCS. I have tried using the PLAN command to have the UCS put back to the default setting, and then resync my 360 Account, but it didn't work.
I just want my UCS and cursor to be normal on screen each time I start a new drawing.
Thanks.
7 REPLIES 7
Message 2 of 8
rkmcswain
I don't know what A360 is doing to it, but the UCS setting is saved in the drawing, per viewport.
If you save a drawing with WCS current, and you close it and re-open it and it's not in WCS - then something is changing it at startup.
If you are starting a NEW drawing and it's not in WCS, then this must be how the template that you are using was last saved. Fix the template.
R.K. McSwain     | CADpanacea | on twitter
Message 3 of 8
imadHabash
Hi and Welcome to AutoDesk Forum,
>> I just want my UCS and cursor to be normal on screen each time I start a new drawing. <<
maybe you have to check your template file (dwt) BUT first let's try to reset autocad for default settings HERE.
Imad Habash
Message 4 of 8
pendean
UCS command is used to put back the default settings of the UCS: PLAN is used to simply follow the UCS setting. Do you need to fix the UCS first?
>>>...opened a drawing which had a rotated UCS, made edits, and closed the file...<<<
The program doesn't know what your default preference is and does not have a function built in to reset files. UCS is a per-file per-tab setting that you ahve to change yourself on purpose.
Hope that helps.
PS: no amount of resetting is going to change that user-input-required reality.
Message 5 of 8
in reply to: pendean
Yes, I think I need to fix the UCS first. Although I have no way of fixing the default setting.
[http://www.minto.com/logo/logo-signature.gif] Thomas Couper
Land Development Coordinator
Minto Communities - Canada
200-180 Kent St, Ottawa, ON, K1P 0B6
T 613.782.5720 | F 613.782.2416
minto.com
You are receiving this email because you may have expressly consented to receive commercial electronic messages from Minto Group of Companies (Minto Properties Inc, Minto Communities Canada Inc., Minto Communities LLC.) and affiliates. To unsubscribe, please click here. Contact Minto Group of Companies at 200-180 Kent Street, Ottawa ON K1P 0B6 or 1-877-751-2852. Click here to access our privacy policy.
The information in this email is intended solely for the addressee(s) named and may contain privileged, confidential or personal information. If you have received this communication in error, please reply by e-mail to the sender and delete or destroy all copies of this message. Any other distribution, disclosure or copying is strictly prohibited.
Message 6 of 8
Emmsleys
Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks for your time.
To add you can click on the image below for steps to reset your settings if you need it.
Sarah Emmsley
Technical Support Specialist
Message 7 of 8
rkmcswain
The default setting of what? UCS?
There is no default setting, it's stored per drawing, per viewport.
Message 8 of 8
JPomeroy
As the others said, it is probably a change that was made to your template that is opening by default- commonly the "acadlt.dwt" file for LT users.  Open that file, adjust the UCS back to what you want (I assume WCS?) and save it as a ".dwt" NOT a .dwg.  Save it as "acadlt.dwt" if that was the original name, overwrite that template with your new UCS/WCS setting, and when you open new drawings, it should be correct.
Technology Administrators
