Rotate view of drawing in modelspace WITHOUT changing the coordinates of each point-AutoCAD LT 2019
I'd like to rotate my entire drawing in model space, which I can do, but it always changes the coordinates of all points.  I'd like to stay the same after rotation as they correspond to Easting and Northing points from a survey I did.  So, in essence rotate the view of the drawing and the entire coordinate system beneath it.
I am a novice.
I am a no
Accepted solutions (3)
cadffm
1. rotate your UCS
 for example: UCS Z 45
2. Change the view to the current ucs
 PLAN current
3. Set your ucs back
 UCS previous
Sebastian
Yes, that works, thank you!  After doing it, is there then a way to force the cursor to be perpendicular also without changing the coordinates?  Thank you.
cadffm
SnapAng?
Sebastian
