Rotate Command
Rotate Command
mbetGEGZX
Message 1 of 9
Rotate Command
mbetGEGZX
Rotate command doesn't rotate objects or moves them in odd way.
Replies (8)
Message 2 of 9
cadffm
But it's working for a Line or Polyline, right?
If yes: These objects are ANNOTATIONs I guess.
Select this Hatch Dimension Blockreference or Text(?) and look into the Prop.Panel (Ctrl+1).
Is Annotation set Yes?
There is also a property like "align to layout".
If no: Start rotate command, select the object, read what Acad says [F2]
Any about locked layers? But then you can also not MOVE the object..
Sebastian
Message 3 of 9
mbetGEGZX
Objects rotate but new mtext and dtext items do not. If I grab an earlier text it will work but not with new text.
Message 4 of 9
pendean
Community Legend
Community Legend
May I ask you to post an actual DWG file with the problem please.
Message 5 of 9
cadffm
Thats what i guess,
learn about Annotation Feature!
At time you are using this feature without to know about.
Start command STYLE, look into your current style, there is Annotation set to ON and also the align to Layout feature.
Use another style or change this property.
Annotative Objecshttps://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/AutoCAD-Core/files/GUID-F8E4E984-71C5-4812-B1A0-3BD0A6BB0BDF-htm.html
Read also other topics, checkout youtube about this, you will find a lot of stuff about this feature.
Sebastian
Message 6 of 9
mbetGEGZX
While I appreciate your reply it is difficult to comprehend.
Message 7 of 9
mbetGEGZX
Sure, let me know how to post it.
Message 8 of 9
steven-g
Look at the properties or in the text style manager
Message 9 of 9
mbetGEGZX
Thank you!
