But it's working for a Line or Polyline, right?
If yes: These objects are ANNOTATIONs I guess.
Select this Hatch Dimension Blockreference or Text(?) and look into the Prop.Panel (Ctrl+1).
Is Annotation set Yes?
There is also a property like "align to layout".
If no: Start rotate command, select the object, read what Acad says [F2]
Any about locked layers? But then you can also not MOVE the object..
Sebastian
Thats what i guess,
learn about Annotation Feature!
At time you are using this feature without to know about.
Start command STYLE, look into your current style, there is Annotation set to ON and also the align to Layout feature.
Use another style or change this property.
Annotative Objecshttps://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/AutoCAD-Core/files/GUID-F8E4E984-71C5-4812-B1A0-3BD0A6BB0BDF-htm.html
Read also other topics, checkout youtube about this, you will find a lot of stuff about this feature.
Sebastian
