AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Right click menu works but functions doesn't work
2 REPLIES 2
344 Views, 2 Replies
Hello everyone,
I'm using autocad LT 2019, I wanted to use the geometric center function, what I did was :
shift+right click to select "geometric center"
but when I do this a message pops up saying " Unknown command" and actually most of the functions don't work only "onsnap settings" and "point filters" work.
Could you please help me ?
2 REPLIES 2
jayhar
Restarting AutoCAD  Do you have a "Default Menu" listed in the CUI under the Shortcut Menus section.
missing "Default Menu" in "ACade.cuix". Simply copied & pasted from "ACad.cuix" file to the acade, & work.
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
pendean
"geometric center" is not a command, it's an OSNAP like INT and END that you can use only when you are already in a command like COPY or MOVE etc.
Technology Administrators
