Removing multiple vertex points from Hatch
andrew_yazbek
andrew_yazbek
Trying to modify a drawing with Hatching that has multiple Vertex points such as the attached image.
I want to delete / remove many of the points byu selecting multiple points at a time. I am using AutoCadLT 2018.
WarrenGeissler
You can't delete multiple selected vertices - BUT - you can remove multiple vertices from a polyline. If your hatch doesn't have a polyline boundary then use RECREATE to build one, then use PEDIT to edit the vertices and remove the ones you don't want.
Warren Geissler
Drafting Manager Denver Water
_____________________________________________
Please ACCEPT AS SOLUTON if this works
(...and doesn't melt your computer or cause Armageddon)
andrew_yazbek
Thank you for the prompt reply, the video really helped!
