@rdoonan2UTU4 wrote:
.... I think there is some setting I need to change in AutoCAD but not sure what.
There is no such option especially since a new name in the path suddenly shows up, that just indicates your copies did not maintain their original pathing.
FYI, "greyed out" does not mean it's working, it just means nothing changed only for autocad. But when you see 1917 show up that means a change did take place outside of autocad.
Ask someone else to make those copies for you, then you try accessing those files (aka take you out of the "move the files" action). Any difference in your autocad?
I also recommend you engage with an I.T. person, at your desk, watch you make copies, be able to trace those copies outside of AutoCAD, you both try to figure out what "1917" has suddenly appeared from outside of AutoCAD. Bet between you all the issue can be resolved.
In the meantime, you can repath to "full path" then try to put it back to "relative path" to keep working: at the end of the day you'd be all done by now and moved on, and that's all our bosses really care about really 🙂
