AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
referenced dwg not updating
9 REPLIES 9
Message 1 of 10
JEFFJW9BB
249 Views, 9 Replies
Please see dwg "L Stairs".  I changed the lines and put them on "0 Layer" and they are "color by layer" (white).
They are referenced into a dwg called "L Stairs Anno" where they are also white.  Correct.
Please see dwg Sheet 1,  on the drawings A7.1 or A7.2 the lines are red.  They should have updated to white. Why not?
9 REPLIES 9
Message 2 of 10
paullimapa
in reply to: JEFFJW9BB
Have you tried putting those Lines on a new layer name instead of 0?
Paul Li
IT Specialist
@The Office
Message 3 of 10
pendean
RED is the color of your 0-VPRT layer in the top file (SHEET1): changing that changes your XREF color. You got what you asked for basically.
Using a viewport color override also changes the color in that viewport without affecting the actual color red, if that 0-VPRT layer must always stay red for whatever reason
HTH
Message 4 of 10
JEFFJW9BB
in reply to: paullimapa
Thank you, I did so and the lines show correctly. But when I go to pdf A7.2 or A7.3 those stair plans do not print!  Why do you think that is?
Message 5 of 10
JEFFJW9BB
in reply to: pendean
Thank you very much.
Message 6 of 10
paullimapa
As @pendean pointed out that the stairs are placed on layer 0-VPRT
That layer is currently set to NoPlot:
So you won't see the stairs placed on that layer when attempting to plot
Paul Li
IT Specialist
@The Office
Message 7 of 10
JEFFJW9BB
Thank you very much for your reply.   I appreciate your help
Message 8 of 10
paullimapa
You are welcome…cheers!!!
Paul Li
IT Specialist
@The Office
Message 9 of 10
JEFFJW9BB
Thank you for your recent reply.  My layers window does not offer such detail.  I am using AutoCAD LT for Mac 2024.  Why does my layers window look SO different?
I attach a screen shot to show you how little information mine shows.
Message 10 of 10
hwalker
@JEFFJW9BB You're better of posting in the MAC forums. The link is below
AutoCAD for Mac
Howard Walker
Left Handed and Proud
Technology Administrators
