AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Re: AutoCAD 2017 fatal error
6 REPLIES 6
564 Views, 6 Replies
I get an Auto CAD Error Aborting every time I try to open a dxf file, using Auto CAD 2017
Do you have an idea why is doing this?
Thank you
6 REPLIES 6
Emmsleys
Hi @Anonymous,
Welcome to the forums!
Fatal errors can happen for a number of reasons. Let's see if we can try and narrow them down for you.
I have a few quick questions:
  • Is the dxf file saved locally or on a server?
  • What OS are you running with AutoCAD 2017?
Sarah Emmsley
Technical Support Specialist
pendean
Any DXF file, or one/a bunch from the same source? post one here.
What is the OS you are using? What video card are you using? 0x0018 Exception errors are often a video card driver error, needing an update.
in reply to: Emmsleys
Good morning,
It is saved on a server, but even when I copy the dxf file to my desktop still don't open
If I use AutoCAD 2016 it does open it without a problem
and I'm running AutoCAD with 64-bit OS
in reply to: pendean
Good morning dean,
It doesn't let me open any dxf files at all
Please see attached dxf file
Thank you
pendean
AutoCAD 2017 seems to open the DXF file you posted just fine here
Emmsleys
Are you up to date with all updates? Build 2017.1.1?
Sarah Emmsley
Technology Administrators
