AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Rastor of architect stamp won't print in color
3 REPLIES 3
483 Views, 3 Replies
I am inserting a rastor image of my architect's stamp,  which shows up in color in a PDF file, but won't print out in color. I am inserting it on a layer that should print red, as my .ctb files indicates.  How do I get my stamp to print in color with black/white prints?
3 REPLIES 3
pendean
What are you printing to?
And what happens if you print to something else, using a different driver and device or output to file (DWF or PDF)?
Your LT version are listed in ABOUT command is what?
in reply to: pendean
I'm printing full sized ARCH C sheets on an HP Designjet T130 wide format
printer. When I save as a .PDF file, the stamp is in red. But when I
print on paper it is not.
My ACAD LT is version 2019.
pendean
Print your PDF to the plotter creates color or not.
If not, your HP driver is set to monochrome somehow somewhere: find out where, if you need more help, try HP's support forums over here https://h30434.www3.hp.com/t5/DesignJet-Large-Format-Printers-and-Digital-Press/bd-p/DesignJet-Large...
HTH
Technology Administrators
