Raster Insert - Hotkey
iant123DM83S
iant123DM83S
Does anyone know if inserting a 'raster image reference' can be done with a 'hotkey'.
At present I navigate to the ribbon/Insert/Raster... with mouse. I searched my pgp file but cant find any raster commands. Is the there a way to insert raster using command line? Ta!
steven-g
Look at the command line when you start the command with your mouse. The command is 'IMAGEATTACH'.
You can add this to your .pgp file for example
II,      *IMAGEATTACH
then save the .pgp file and don't forget to then run REINIT and select the tick-box for .pgp so now you can start the command by just typing 'ii' (that's a personal choice I always use a double letter rather than having to hunt for two different keys)
iant123DM83S
Hi Steven-g
That worked a treat. I love the double letter idea to replace IMAGEATTACH; to me 'ii' is a breeze to remember as "Insert Image". Couldn't have done it without the help made easy. Ta!
