Quick select
Quick select
Quick select
Hi, my quick select doesn't show any properties so I'm unable to use it. I have tried new drawings and the audit command with no avail. please can someone point me in the right direction for the fix?
cheers in advance
pendean
Community Legend
Community Legend
Restart your PC and try again. Post back if that's still an issue.
I’ve tried the following:
Reboot pc and acad
Audit
Repair acad
New drawing
Drawings from other cad technicians
Windows updates
Acad updates
pendean
Community Legend
Community Legend
So this happens in all files, correct?
LT2014 is 5-years old, what's new or different with your setup today that was not the case last week/month/year/two-three-four-five years ago?
Or is it this https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/Windows-...
in which case you might want to start here for fixes https://www.longbowsoftware.com/Tips_and_Tricks.php
Dan.Scales
Hi @Anonymous,
Is there any third party application running on top of AutoCAD?
Also, try resetting AutoCAD to defaults:
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-reset-AutoCAD-to-defaults.html
Dan
Dan Scales
