Quick Properties palette is displayed partially
marco.baldissara
marco.baldissara
Offen, when I select some object, the  Quick Properties shows fewer rows than expected, even though I previously set the Quick properties setting.
Anyone have the same problem or know the way to fix it?
Thanks in advance
pendean
Community Legend
Community Legend
Greetings @marco.baldissara
Your posted screenshot does not actually show your problem, it's just a general setting for QPM's pop-up. Try again?
If all you want to see are more options in QPM (and what your missing screenshots of actual QPM at objects might show), those extras must be turned on and set by you for each and every object type in your files using CUI command's QUICK PROPERTIES section as shown below using LINE object type as an example
Hope that helps.
marco.baldissara
Thanks Pendean for your reply, unfortunately I can't reproduce the error in my autocad but the first time the quick properties didn't show more than 5 lines even though I set the custom properties correctly (I selected about 10 properties related to the Circle element) and there was no way to fix this.
Anyway, now I solved the problem following the solution for an old bug reported for ACAD 2019, so I selected an item and selected ALL properties, save and close AutoCAD. Restart again and the problem is fixed.
I know, it's strange, but... it works for me.
Bye!
jgilbertLVGA2
Community Visitor
Community Visitor
This worked for me.  Very frustrating trying to figure this out.  Thank you!
