Publish Cropped, Plot Good?
Hi, can anyone advice me why my title blocks are partially cropped when using the Publish command but when I use the plot command they come out fine?
pendean
Community Legend
Community Legend
Your "what to plot" or "page size" or "margins" (or all three) is different between the two processes you engaged: dig a lot deeper about what is being used, don't assume what you want is being selected automatically.
I have solved the problem by the following method:
Using the plot command select the paper size with the 'full bleed' option
Use 'Apply to Layout' and then cancel the plot
Repeat for each of the sheet views
Use the Publish command
pendean
Community Legend
Community Legend
You can also use PAGESETUP command to do all of that, and skip the part about "...then cancel the plot..."
Thank you for that tip!
