Proxy pac file about
Hello Support,
We are use proxy device and proxy pack file.
Autocad not working when checked pack file. but when uncheck autocad is work.
Can you help us?
Pack File Detail:
function FindProxyForURL(url, host)
// Define proxy server
var proxyserver = "PROXY 192.16x.x.x:8080";
// Make host lowercase
var lhost = host.toLowerCase();
host = lhost;
var lurl = url.toLowerCase();
url = lurl;
//SUB-FQDNs of ExpressRoutable wildcards which need to be explicitly sent to the proxy at the top of the PAC because they arent ER routable
if ((shExpMatch(host, "*.click.email.microsoftonline.com"))
|| (shExpMatch(host, "*.portal.microsoftonline.com")))
return "DIRECT";
//EXPRESS ROUTE DIRECT
else if ((isPlainHostName(host))
|| (shExpMatch(host, "*.asm.skype.com"))
|| (isPlainHostName(host)))
return "DIRECT";
// If Azure public peering is available the following can be added to the Expressroute section above and sent direct via ER. If not these can be sent via the internet i.e delete them from the PAC file.
//*.adhybridhealth.azure.com
//Catchall for all other traffic to proxy
else
return "DIRECT";
Best Regards
john.vellek
Hi @Anonymous,
From my understanding, this type of proxy is not supported.  Please see this AKN Article .
To verify though, if the user bypasses proxy servers they can validate their license correct?
If they pass through proxy server they still have no issues?
So it is just the PAC file that is causing the issue? Is there a way in AD/GPO to apply a different condition just for your AutoCAD users (allow them manual configuration of proxy settings)?
John Vellek
john.vellek
Hi @Anonymous,
I am coming back to your thread to see if the issue or question you posed has been resolved.   Please let me know if the suggestions I provided have provided  a workaround or offered insight as to why the connections cannot be completed.
John Vellek
Unfortunately, We did not find a solution to this issue. We are looking for solutions.
We use the 2016 LT version. Do you have the same problem in 2017 and 2018 versions?
Best Regards,
pendean
Community Legend
Community Legend
Download the free trial of LT2019 (the current version) and find out for yourself with your own files on your own computers https://www.autodesk.com/products/autocad-lt/free-trial
john.vellek
HI @Anonymous,
As I indicated previously, to the best of my knowledge, AutoCAD will not work through this kind of proxy configuration.
The typical proxy settings can be found in this article
John Vellek
