program not responding
I am running Autocad LT2011 on window 7 The program is running fine i do all drafting , but it will hang and give a message "program not responding" - once you go for command such save as, export, plot ..etc
pendean
Community Legend
Community Legend
If you have it installed, uninstall DROPBOX then restart Windows and see if your problem goes away.
Emmsleys
It appears DropBox came out with an update over the weekend that may cause issues opening files when using older versions of Autodesk products. Other customers have had similar issues.
This article walks you through removing DropBox and doing a restart. It appears reinstalling Dropbox does not fix the issue, so we advise waiting until a patch is released by DropBox.
Sarah Emmsley
Technical Support Specialist
Emmsleys
Post back should you continue to have issues with AutoCAD.
Sarah Emmsley
