This has not happened before. I was trying to make a block of an elevation, no more than 150 objects and the program had a FATAL ERROR; I tryed again and again and always the same fatality
Does anyone know what to do?
Thank you...
I'm using AutoCAD LT 2007
Thank you...
WBLOCK command will make a bloxk too, try it.
If it craahes, it may be an ovject in your selection, or you just need to fix your file.
