problem with stretching - dimensions move
Message 1 of 15
hello, when I am stretching my drawings, some of my dimensions move and do not stay where the nodes were originally place. here is a video i took.
https://youtu.be/p6rL3B8DuUk
thank you
Tim Rudie
Tri City Glass & Door
contract # 110002704762
Replies (14)
Message 2 of 15
imadHabash
would you please share with us that file ? we need just those dimension lines and some lines around .
Imad Habash
Message 3 of 15
pendean
Community Legend
Community Legend
Does this happen in all files, or just this one (or just this one elevation)?
Message 4 of 15
All files, not sure if it is a setting issue???
Message 5 of 15
I tried sending it, but it is 11MB and 9MB is the max
Message 6 of 15
pendean
Community Legend
Community Legend
That's your email limit most likely.
Either way, you have to come to the website to post files by replying to someone: and the limit is 100MB I believe.
Message 7 of 15
I did send an email via the website just now.
thnks
Message 8 of 15
pendean
Community Legend
Community Legend
"sending email" is not how you post DWG files here in the forums sadly.
Message 9 of 15
imadHabash
take a copy from your drawing then erase every thing except the part that you show to us in your previous video .  then Purge and Audit your new file to delete all unwanted items . Now you have a small size file that you can share with . 🙂
Imad Habash
Message 10 of 15
h_s_walker
Your dimensions are associated to the objects you originally dimensioned. So if you stretch the object the dimension will stretch with it.
First at the command line type DIMASSOC and change the value to 1. See this link https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Functi... for more information.
2. At the command line type DIMDISASSOCIATE and then select the dimensions you don't want to move or type ALL to disassociate all dimensions from the objects.
Howard Walker
Left Handed and Proud
Message 11 of 15
Is there a way to DIMDISASSOCIATE set to 1 prior to starting any drawing? I can apply this setting and it works for the current dimensions, but when I draw new, it reverts back to 2
Message 12 of 15
h_s_walker
Open up your template drawing. Change the DIMASSOC setting to 1 in there.
Save the template file. Now every time you start a new drawing using your template the dimensions will not move.
Howard Walker
Message 13 of 15
mgcm1988
Community Visitor
Community Visitor
It didn't work for me.. measurement still moving when I try to stretch node.
Message 14 of 15
pendean
Community Legend
Community Legend
Show us: share your DWG file here, point inside it for us to replicate your issue.
Message 15 of 15
kaushal_djwfm23
Community Visitor
Community Visitor
You can use DDA command to disassociate dimensions from being stretched.
