problem with selection on the screen
when i click on the autocad screnn appears these little cross
such as turning off this variable ?
grateful for the attention of all
h_s_walker
What version of LT are you using? As of LT2012 they should not be appearing.
Before 2012 you need to type in BLIPMODE and turn them OFF
Howard Walker
Left Handed and Proud
use 2016
the blipmode command in 2016 does not exist ?
h_s_walker
No.
Hae you tried turning HARDWARE ACCELERATION ON/OFF?
Howard Walker
pendean
Community Legend
Community Legend
.BLIPMODE is the command name (has a dot as part of the name), it needs to be off.
Otherwise, if it is off, start GRAPHICSCONFIG command and turn off LINESMOOTHING and LINEFADING first, then everything else second until your video card behaves better.
