AutoCAD LT Forum
Problem with "Fit To Paper" plot option
4 REPLIES 4
BillW435
24942 Views, 4 Replies
BillW435
What I'm trying to do is have my layout fit the paper size I have selected for plotting. Problem is, the "Fit To Paper" option box is grayed out. Also grayed out is the option for centering the drawing on the paper. I have tried all the usual things to fix this, including (surprise) reading the user's guide instructions, which are copied below:
"1.  Click Output tab > Plot panel > Plot.
2.  In the Plot dialog box, under Plot Scale, select the Fit to Paper option.
The resulting scale is automatically calculated. The ratio of plotted units to drawing units in the custom scale boxes is displayed.
 3.  Click OK to plot the drawing."
What am I doing wrong? Appreciate your help.
Bill
AutoCad LT 2011
Windows XP
Bill
AutoCad LT 2011
Windows XP
4 REPLIES 4
drjohn
in reply to: BillW435
drjohn
Review your setting of what to plot.  eg: Extents, Display, Window ...  etc
There's a roll down for that in the plot panel.
HTH
DJ
HTH
DJ
BillW435
in reply to: drjohn
BillW435
Thanks DJ.
Yes, the "Fit to Paper" box became available when I set the plot option to "Extents". However, from what I have read, the "Fit to Paper " option should also be available with the plot option set to "Layout".
But at least now I can get the job plotted.
Grateful.
Bill
Thanks DJ.
Grateful.
Bill
pendean
pendean
Community Legend
Community Legend
Fit to paper and Layout cancel each other out: where did you read this choice?
BillW435
in reply to: pendean
BillW435
Dean, not sure what you meant about "Fit to paper and Layout cancel each other out".  I did not read that. However, I now realize that you con't both set a scale option and have the "Fit to paper " option.
Thanks.
Bill
Thanks.
Bill
Technology Administrators
