problem with printing with transparency
besame1
Message 1 of 10
besame1
(view in My Videos)
Replies (9)
Message 2 of 10
paullimapa
Instead of printing to your printer gave you tried printing to pdf using Dwg to pdf.pc3?
Also why is your paper size so long with blank empty space?
Paul Li
IT Specialist
@The Office
Message 3 of 10
besame1
It prints to PDF without any problem, but I want to print directly. The paper is long because I print different sizes of ribbons and the paper is set to the maximum length.
Message 4 of 10
paullimapa
Then most likely your print driver does not support transparency.
Paul Li
IT Specialist
@The Office
Message 5 of 10
besame1
Impossible. I have an HP designjet t520 plotter and I also tried printing on the same plotter with a friend and there is no problem.
Message 6 of 10
paullimapa
I would double check everything to make sure what you're doing on your friend's computer is exactly setup the same as your computer. Whatever the difference is that's where the problem lies.
Paul Li
IT Specialist
@The Office
Message 7 of 10
besame1
Maybe it's a compatibility problem between windows 10 and autocad lt 2015? Maybe someone uses AutoCAD LT 2015 with Windows 10?
Message 8 of 10
paullimapa
Is that the major difference between your friend's computer and yours?
Items to compare:
Windows OS version
AutoCAD Version including service pack updates
Printer driver version
This all assumes you're both plotting to the same plotter so that's not a variable
Paul Li
IT Specialist
@The Office
Message 9 of 10
besame1
123.jpgProblem solved. In the printer options, I changed the print quality option from "normal" to "fast". I thought about it for half a year 😀
Message 10 of 10
paullimapa
Ah so that cause 2022 to also not work and not just a problem with 2024 then.
Paul Li
IT Specialist
@The Office
