Problem with DXF
Problem with DXF
baddipl
Problem with DXF
baddipl
I want to create a DXF file. I am using Fusion 360. And...
1. I created 2d drawing of the object in Fusion 360.
2. Exported this drawing as DWG file
3. Imported to Autodesk LT
4. Save as DXF
DXF doent has any construction lines, only symmetry axis and dimensions....
john.vellek
HI @baddipl,
How did the drawing file look when you brought it into AutoCAD LT?  Can you share the DWG so I can play with it?
How did you create the DXF file and what program are you using to view the DXF?
John Vellek
pendean
Community Legend
Community Legend
Are your objects on a locked layer?
What method did you use to create the DXF?
Show us, post your DXF and your source DWG file if you can.
john.vellek
hi @baddipl,
i haven't seen you back in the thread. have you resolved your DXF issue? Was it the export from Fusion 360 or something else?
John Vellek
