Problem with automatic control
Message 1 of 11
Hi, I'm stuck with the drawing, I have a problem with all curve lines witch became automatically an only polyline.
Despite I saved the drawing file, when i reopen the same file all curve line in the solid became automatically polilyne.
I don't know how to solve the problem. I ask politely if someone could teach me how to solve the problem.Thanks.
Replies (10)
Message 2 of 11
h_s_walker
Welcome to the Forums
It sounds like your displaying of arcs is off
At the command line type OPTIONS
The dialog box which comes up choose the DISPLAY tab
To the right you will see DISPLAY RESOLUTION
and below that
ARC AND CIRCLE SMOOTHNESS
SEGMENTS IN A POLYINE CURVE
Increase both numbers. I have them set at 20000.
Howard Walker
Left Handed and Proud
Message 3 of 11
I tried with this method but it doesn't work. I still have the problem.
Message 4 of 11
h_s_walker
Can you post the offending drawing here so we can have a look at it
Howard Walker
Message 5 of 11
I send you the screeshots with both images: the first is correct and the second that is wrong.
Message 6 of 11
h_s_walker
Yes what I said first is correct.
After you've changed the numbers do a REGEN of the drawing.
Howard Walker
Message 7 of 11
yes it works your method but after i saved the drawing, when i reopen the same file the problem return.
Message 8 of 11
if i make smaller the solid with the zoom, when i enlarge the solid the problem return
Message 9 of 11
pendean
Community Legend
Community Legend
Your video card just can't keep up with AutoCAD: you must use REGEN or REGENALL commands often to help it along. Ensure REGENAUTO and REGEMODE are on is about all else you can do.
Message 10 of 11
I think that your solution it is correct maybe the video card can't keep up with autocad i will have to use the command REGEN.
Message 11 of 11
Thank you so much for all advices.
