Printing Issue
Printing Issue
Printing Issue
Recently, we have a bought Zebra GX430t label printer. I am having trouble in printing labels through Autocad with Zebra printer. I can print thorough Word, Adobe etc. Can you help me with that?
Info:
Product Autodesk AutoCAD LT 2016
Serial number  xxx-xxxxxxxx
Product key  057H1
rkmcswain
What kind of trouble?
If you configure the page setup correctly, with the proper page size, margins, etc. then it should work.
Work on the page setup until the PREVIEW command gives you exactly what you want.
This will save labels/paper while you're testing.
P.S. Nobody here in these public forums needs your serial number.
R.K. McSwain     | CADpanacea | on twitter
Hi:
It does not print label.; Preview is fine, it shows exactly how it should be.
pendean
Community Legend
Community Legend
>>>... printing labels through Autocad with Zebra printer...<<<
Why? Did the label maker not come with software?
Does your AutoCAD plot to PDF or any other printer with the same plot parameters? If yes, use your PDF reader to print to the label printer, does it work?
Hi:
Yes, it works that way, but I don't want to convert to pdf, and then print the labels. I want to print directly from the Autocad.
Andy
pendean
Community Legend
Community Legend
If you see a PREVIEW and it's fine then AutoCAD is working well.
So the challenge must be the driver is not capable of handling the output coming from AutoCAD.
There is nothing inside AutoCAD to fix that: you'll need to see if the driver offers any options you can try or settings it needs to be on or off.
And in the meantime you can print from PDF.
