AutoCAD LT Forum
Preview of Drawing shows Text Bolded but PDF'd Document shows normal Text
8 REPLIES 8
Message 1 of 9
Braird_Engineers
1011 Views, 8 Replies
I am trying to have the MTEXT on my drawing to show is thicker and bolded, it seems to work fine in the preview but the finished PDF document after printing comes out as normal thin line.
How can I achieve this?
Tags (3)
Labels (3)
8 REPLIES 8
Message 2 of 9
pendean
in reply to: Braird_Engineers
SHX or TTF fonts?
How are line weights being handled when plotting to PDF? Do you need to change plot style tables or settings?
Message 3 of 9
Braird_Engineers
in reply to: pendean
This is regarding TTF Font, the blocks which are on certain layer come out as bold and thick, it is just the text font which does not differ.
Can you let me know which settings to try and adjust?
Message 4 of 9
pendean
Thanks for the extra information: TTF fonts ignore any line weight settings you apply to them in AutoCAD/LT: but your issue could either be how font handling is addressed in your chosen PDF driver or the fact that there is nothing wrong with the PDF, just your PDF viewer's display.
Can you show us what you see on your screen? Include the PDF and DWG as well please.
Message 5 of 9
Braird_Engineers
Please find attached as requested, I will attach the last one next.
Message 6 of 9
Braird_Engineers
The PDF'd document
Message 7 of 9
pendean
Your choice of CLIBRI-LIGHT is most likely your issue: you opted for what you got, a light/faint font.
Select a more robust font in AutoCAD to use instead.
And yes, even make it "bold" is not enough, its just the wrong choice of font.
HTH
Message 8 of 9
Braird_Engineers
I will trial a different font, can you suggest a similar one which looks like Calibri light?
Message 9 of 9
Braird_Engineers
Calibri fixes the problem, thank you.
Greatly appreciated, such a genius!
Technology Administrators
