Plotting transparency - Everything comes out lighter
Message 1 of 22
So i am using ACAD LT 2021 and plotting from paperspace, here is my plot setup
When i preview the plot everything looks correct as shown here
But when i complete the plot this is what comes out, with everything faded or lighter.
Pulling my hair out with this one as I cant work what is wrong.  If I turn on "plot object lineweights" it works but then i have a poor quality plot as shown here
some advice would be greatly appricated
Replies (21)
Message 2 of 22
cadffm
i guess it is your PDF-Viewer on the one side and on the other side your lineweight setting (objects and/or Layers).
Without the dwg file, we can not check these things.
Your title is Plotting transparency, why?
Sebastian
Message 3 of 22
Plotting transparency is what i am trying to do and is the only time i have this issue.
Its not the pdf viewer as if i plot straight to printer or try a difernt pdf tool the same issues applies
Message 4 of 22
here is the dwg if you would like to see
Message 5 of 22
cadffm
Nothing sounds like an issue, just the minimum lineweight (what is used wjile printing without lineweights) + transparency properties are to thin/bright
and your lineweight setting of the text in your title is to thick for a well looking text.
I guess you are using 'Plot with lineweights' ON for usual , or not?
Share a sample dwg and every one can search for the settings and the problem.
Sebastian
Message 6 of 22
cadffm
i opend your file, set "DWG to PDF.pc3" as printer, saw that
your 'transparency' plot setting was DISabled??
I turned it ON
This is the result:
PDF and Screenshot of the PDF on my PDFviewer &  plot setting
Sebastian
Message 7 of 22
Ok great, so it works for you but doenst answer my problem .
I still cant get the same result
Message 8 of 22
cadffm
I checked the text inside your title block,
the lineweight is ByLayer,
the Layer is 'TITLE BLOCK',
the layer lineweight is DEFAULT.
"default" is a bad choice, but ok. What is your default lineweight?
Standard is 25 (0.25) and i used this for the plot.
Whats your setting? Command LWDEFAULT
Sebastian
Message 9 of 22
cadffm
It help to find your problem.
1. Is the PDF ok for you, looks fine?
2. Try the same setting, how looks this PDF, created with 'DWG to PDF.pc3' ?
Sebastian
Message 10 of 22
cadffm
May i ask why?
Because i can not find any objects with a transparency value other then bylayer
and the layer transparency is set to 0.
Plotting with transparency is useless, the only possible result is getting trouble with this.
Sebastian
Message 11 of 22
i reloaded the .pc3 file and it seemed to work using dwg to pdf.. but now the aodbe acrobat X doesnt print the transparency objects... even on the pdf you sent me .. uggghhh
Message 12 of 22
I have transparency on layer "PC_CONCRETE" I find it makes the layout easier to understand or do you have a better way of doing this?
Message 13 of 22
cadffm
PC_CONCRETE, Sorry . I missed that, thanks for pointing this out
Okay, your program and settings working fine, it is just a problem
with your favorite printer configuration (Adobe).
The only hint from me: Is your program updated?
Which product (name and version) are you using?
Command: ABOUT
Sebastian
Message 14 of 22
currently R.47.0.0 autocad LT 2021
Message 15 of 22
cadffm
Try the first&latest update: 2021.1
https://help.autodesk.com/view/ACDLT/2021/ENU/?guid=AUTOCADLT_2021_1_FIXED_ISSUES
The kind of ReadMe isn't much detailed, you have to test it.
Login to your account and download AutoCAD LT 2021.1
https://manage.autodesk.com/cep
HTH
Sebastian
Message 16 of 22
pendean
Community Legend
Community Legend
As you found out, this driver is garbage or AutoCAD Users
Message 17 of 22
Well i still havent resolved this and its doing my head in.
Now that i have changed to dwg to pdf and not ticking "plot object lineweights" the pdfs look great and nice clear..  HOW EVER!!! when i print they came out really faint, i have tried differnt PDF applications etc and get the same problem
anyone can help ??? @cadffm ???? @pendean ????
Message 18 of 22
also i updated to latest update and still have the same issue
Message 19 of 22
cadffm
And WITHOUT 'Plot transparency' that works different and as expected?
Sorry, but without 'Plot lineweights', the lines are just to thin for this color.
Without 'Plot lineweights' , an ortho BLACK line,
the printer tries to plot the thinnest possible continuous line
Same line, but in color grey
Printer print the same data, but because of the color grey instead black, it prints only every second ink dot
It looks like grey, but also "thinner".
I guess you are talking about usual things, i can not see an issue here !?
Please try it one time with: Change all colors to 7, print again without lineweights, but with plot transparency.
I am out, sorry.
Sebastian
Message 20 of 22
Maybe try printing with a smaller paper size?
I used to have the same problem but exporting the PDF as A3 instead of A1 fixed it for me.
