Plotting Help!
Plotting Help!
heatherCWRL4
Plotting Help!
heatherCWRL4
Community Visitor
Community Visitor
I'm currently using the AutoCAD LT trial and am having trouble plotting.  I cannot get it to plot to scale, or on the correct size paper.  Even when I choose 18" x 24" it keeps plotting on 22" x 22".  Before I can even get that far though, every time I preview it, it shows it's tiny in the bottom corner, even though I'm choosing 1:1.  Please help!!  Much appreciated.
rkmcswain
First question, are you trying to print from Model Space or from a layout?
If the latter, then make sure you run the PAGESETUP command and configure everything, such a printer, page size, scale, plot style, etc. Once you do all that, your "paper" in the layout should be visible and you can see how your border/title block fits on it.
If you are trying to print from Model Space, then please consider printing from a layout.
I could write a WALL of info on this, but this work has already been done dozens of times, just look on Youtube. AutoCAD and AutoCAD LT are the same as far a printing are concerned. Don't worry about "publishing" for now, but once you get the PAGESETUP command down, then your layout is always ready to print or publish.
pendean
Community Legend
Community Legend
Show us your work; post your DWG file here for everyone to examine.
