AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Plot to PDF filename not auto filling
2 REPLIES 2
423 Views, 2 Replies
Using a 3rd part pdf creator such as pdf complete, CutePDF, etc. when it is time to save the pdf I have to manually type the filename since it does not auto fill.  Using AutoCad LT 2019.  My previous version was Autocad 2006 and it successfully auto filled the filename.
Any idea how to remedy this?
Thanks.
2 REPLIES 2
cadffm
For third part software (and driver) take a look there.
Inside the pdf driver you will find the point for the filename (if available).
For pdfcreater i am sure you can setup the filename to autofill.
Sebastian
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD LT forum. Welcome to the Autodesk Community!
 I do not have either of those 3rd party PDF drivers so I can't test in my AutoCAD.  Do either driver include any settings/preferences/options where you can set some defaults?
I suggest that you contact their support sites to see if they might be able to offer some suggestions.
John Vellek
Technology Administrators
