Plot/ no plot button/ column not visible in Layer manager AutoCAD LT 2022
cmeddock
cmeddock
The plot/ no plot button and column have disappeared from my layer manager. For example, I need to create a layer called NOPLOT (similar to defpoints) and hence one of the options after I name it and give it a color and lineweight would be to click the button to prevent that layer from plotting so that I don't have to worry about turning it off each time before plotting. Is this something new or is mine broken? Thanks
pendean
Community Legend
Community Legend
mac platform? You are in the wrong forum, that is over here for LT as well as full AutoCAD https://forums.autodesk.com/t5/autocad-for-mac/ct-p/4051
In Windows versions, you simply right-click here to turn on/off those columns
cmeddock
Thank you @pendean That worked on Mac too! And thank you for the tip being in the wrong forum. I didn't realize. 🤦🏼‍♂️
