Pick box is rectangle not square (Crosshair box)
NormsAUS
Message 1 of 66
NormsAUS
I am often getting onto other PC's and finding that the crosshair pickbox (curser) is rectangle and not square.
I have looked in op (options) but no luck.
Any suggestions.
TIA 🙂
Replies (65)
Message 41 of 66
sarchwba
Out of curiosity would you mind activating it with Ctrl+9 and making sure it's docked to the bottom of the screen?  I mentioned F2 but that is a different command window.
I just turned off my command line and the glitch happened until I turned it back on.
Message 42 of 66
joehovarter
At one time I had written a lisp to set the acad window to 1 or 2 pixels smaller than full screen. This would also fix it. I am having trouble finding it now but it probably wouldn’t specifically work for you anyway.
Don’t be confused this has nothing to do with your screen resolution, this is an issue with application window size. And what area is left over for the actual drawing window.
Message 43 of 66
nrz13
Turning on and docking the command line restores the correct pick box proportion as expected (as outlined in previous posts above).  Not a solution for me, though, since I don't use the command line.
I only mentioned the resolution because a common response in the posts above was to tell people they weren't running their screens at native resolution.  I'm well aware of this bug (and it is a bug).  It has been around forever, but I was just checking to see if there was anything new on it.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 64GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
Message 44 of 66
RobDraw
If it were an AutoCAD bug, then everyone could replicate it. Even my low end machine with an economy video card has a square pickbox.
I think you might be barking up the wrong tree.
Rob
Message 45 of 66
joehovarter
That doesn’t make any sense. That’s like saying snow doesn’t exist because you live in Florida. The fact that it is hard to replicate doesn’t mean it’s not there.
I will say this again... it is specific to drawing area pixel size. Many things factor in how much area you have. What toolbars are open, comma line open or not, or how many lines of comma line are visible.
Back when I initially started seeing this I was using drawing tabs. The rectangle pickbox only showed up when two drawings were open. Meaning the tabs appeared shorting my drawing window height.
Message 46 of 66
RobDraw
This is your mistake. We are using the same program, AutoCAD. The differences are in hardware.
Get it?
Rob
Message 47 of 66
joehovarter
Are you serious right now? Troll somewhere else.
Message 48 of 66
joehovarter
Steps to reproduce,
open ACAD and new drawing
with command line docked at bottom of screen, drag top of command line slightly to change its size in increments as small as possible. Took me one try, pickbox went rectangular. To reproduce a second time took me less than 10 tries.
See images, one shows a circle and a square, in the second the only thing that changes is the pickbox.
Message 49 of 66
RobDraw
You're putting an awful lot of effort into something that has no significance whatsoever. It's a graphic glitch. BFD...
Rob
Message 50 of 66
nrz13
I'll be sure to report this problem on the Adobe user forums then.  😆
Hey, Rob, you don't work for Microsoft, by chance do you?  This is a select "feature" for select users, right?  😆
@RobDraw wrote:
This is your mistake. We are using the same program, AutoCAD. The differences are in hardware..
Please do let us all know the one single hardware configuration AutoCAD is supposed to run on.  I missed that on the AutoCAD system requirements page.
@RobDraw wrote:
You're putting an awful lot of effort into something that has no significance whatsoever. It's a graphic glitch. BFD....
Heaven forfend that someone want to put effort into resolving a graphical glitch that's more than 2 decades old in a graphical-oriented program.  If it doesn't bother you, there's no need to chime in just to try to invalidate someone else's experience.  At least the work-around solutions to this bug posted here may be helpful to others with this problem.
Message 51 of 66
RobDraw
You too?
Can't see the forest for the trees?
Rob
Message 52 of 66
joehovarter
If it has no significance why are you still responding? This is simply an example of someone who can’t admit they are wrong and continues to project their opinion on others.
This isn’t a fluke. I can see it happening on my screen and the fact that others are posting seeing the same thing validates that.
It’s obvious you have nothing else to contribute so walk away.
Message 53 of 66
nrz13
Just discussing a leaf at the moment...  Care to join us, or would you prefer to go back to the forest?
Message 54 of 66
RobDraw
A funny thing happens when I make valid points that people don't like. They make it personal and tell me to go away instead of admitting that I do have a point. It's quite immature actually.
Rob
Message 55 of 66
joehovarter
Well that's where you are wrong. You haven't made any point.
You are STILL putting an awful lot of effort in this.
Message 56 of 66
sarchwba
Don't worry you're right.  He may not be trolling but he's not here to help either.
If he doesn't think that this is a bug because it can't be produced by every single user then there's no point in discussing it with him beyond that.
Message 57 of 66
RobDraw
... and if you all refuse to realize that it could be a simple minor graphic glitch, I am wasting my time.
Rob
Message 58 of 66
joehovarter
I would also like to add I was able to reproduce on AutoCAD 2021 for MAC by dragging the application window smaller from top to bottom.
Message 59 of 66
RobDraw
Two different programs, same hardware. Things that make you say, "Hmmm..."
Rob
Message 60 of 66
joehovarter
I’m not really sure why you would think a MAC would be same hardware. Replicated currently on desktop, laptop and now a MacBook Air.
Besides hardware is not the issue here and that’s been proven.
What exactly are your motives at this point?
Again, if you have no valid input, go away.
