Is there a way to have the LTscale in paperspace to permanently be set to 1? Either in
There have been so many times when we are drawing with the LTscale at 1:00 for example to see the lines and dashes, go to plot and realize afterwards that we forgot to change the scale and have to go back and replot everything.
Thanks in advance!
Solved by pendean. Go to Solution.
Sebastian
What version of LT are you using?
Howard Walker
Which version do you have? Look into your Help [F1] if sysvarmonitor is available or not..
_sysvarmonitor works well in LT too, but is only available in Version since 2016
The rest of the description is difficult to interpret.
Please inform yourself about PSLTSCALE and MSLTSCALE [F1] and test with them in a copy of your file to understand how they works.
Sebastian
