We have 2005LT for kitchen design. I need to recover or find a pen assignment. The "Plot Syle Table (pen assignments) window is showing "peacock.ctb (missing)." Is there a way to recover this setting?
Just some clarification. Has autocad lost the location of the .stb file, or you never had it. If you have received the .dwg file from someone else, such as a client, they should have also supplied the relevant plot style table.
Search your hard drive or server for the missing file. When you find it, either add its folder to the search paths in Options, or copy it into a folder that's already in the search paths.
If you can't find it, check your backups.
If it is not there someone deleted the file. Look in the Recycle bin as well
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
