I am having a problem with dwg to pdf files. I am running Autocad LT 2017 on Windows 10 system. The main printer for our large prints is a KIP 7170 (black only). I've been able to print directly to the KIP printer with a DWG file and they come out fine and just how I want them. If I save them as a PDF of any type (high quality, general, etc...), then all hell breaks loose. Especially through email trying to reproduce the same PDF file. sometimes it just comes out with much lesser quality and jagged lines and such, other times almost the entire drawing is missing, even though the PDF peview looked completely fine. I have tried so many diferent settings and options and am at a total standstill. Not sure if it all an Adobe issue or how I am saving the files or settings within. I'm trying two diferent Adobe(s). Acobat Reader DC and Acrobat Reader 11.0 and just having no luck. Adobe doesnt seem to have real good options for actually contacting customer support from what I've seen either.
Here are the files. I guess it seemed as it could have been an Adobe issue. We've them in our office before. I have tried high quality, general, small, dwg to pdf and still haven't found the problem. Could it be a STB or CTB issue?
I have also tried changing the DPI (mostly higher) and print as image, still no luck. Also, the PDF prints fine from a small Cannon printer but not the Kip printer.
Hi @Anonymous,
Which Kip diver are you using and how is the device set up on your network?
Have you tried sending the PDF to the Kip directly (ip address) rather than to a network queue?
