path files
path files
path files
I am working in Autocadd 16LT. All of a sudden the path file has started showing up on all of my copies. It does not show up in the drawing but only when I print. Please HELP
Johneng
Is this a plot stamp? In your plot dialog box is the box next to "Plot stamp on" checked?
http://help.autodesk.com/view/ACDLT/2018/ENU/?guid=GUID-C2A21C73-CCA6-42E6-8D7B-D2B429046FB0
Tiana_Y
Hi @Anonymous ,
I'm just checking in to see if you need more help with this. Did the suggestion that @Johneng  provided work for you? Also another solution to try is installing Service Pack 1 for AutoCAD LT:
AutoCAD 2016 Service Pack 1
AutoCAD LT 2016 Service Pack 1
Prior to the service pack, to turn off the stuck tooltip, click back to the Start Tab and move the mouse cursor around. The tooltip will disappear. Click back to your drawing window. Additionally, you could stop the tooltip from appearing by doing one of the following:
  • Set the STARTMODE variable to 0 (zero). You may also want to set STARTUP to 0 (zero).
  • Set the 'Number of recently-used files' in Options under the Open and Save tab to 0 (zero).
  • Close the Design Feed palette.
I hope this helps!
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Tiana.D
Community Program Manager
Contact Autodesk Support
