Paste range of cells from Excel into AutoCAD table
Crass
Message 1 of 19
Crass
I simply want to paste a series of cells from excel into an existing autocad table. About 8 rows, 1 column thick. I want the values to acquire the destination formatting too if possible. I do not want to create an OLE object or anything fancy. I have seen instructions to use "Paste Special" on forums, but I do not have this choice when I right-click. I'm sure this is possible.
Any help would be greatly appreciated.
AutoCAD 2018/2021
AutoCAD Civil 3D 2021
Replies (18)
Message 2 of 19
pendean
Community Legend
Community Legend
PASTESPEC is the command name, type it.
Look up usage in Help.
Message 3 of 19
Crass
The PASTESPEC command is helpful to know.
However, I still do not see how you can "paste as rows" - this is the nomenclature from Ms Word.
When I go into an AutoCad table cell, I do have "Paste Special" > "Paste without Character Formatting" as the only option. This pastes all data for multiple rows into one cell. I want to enter data into multiple rows at once:
Excel Row 1 > Cad Row 5,
Excel Row 2 > Cad Row 6,
Excel Row 3 > Cad Row 7,
etc ...
AutoCAD 2018/2021
Message 4 of 19
pendean
Community Legend
Community Legend
There is no 'paste as rows" in AutoCAD: you can only paste what you pre-select and copy in Excel.
The choices of the command are worth exploring in HELP, as well as testing: try each and explore what they offer and if that meets your needs.
Message 5 of 19
Crass
FYI, This is the best solution for my situation:
  1. PASTESPEC
  2. Paste as AutoCad Entities
  3. This creates a brand new AutoCAD table. You can select the range of columns and rows you like, copy
  4. Paste into exiting AutoCAD table.
I can update multiple cells at once, which is a big timesaver in this case.
Thanks Dean.
AutoCAD 2018/2021
Message 6 of 19
After you have copied the area from Excel, go into AutoCad and do not right click instead click on edit button then click on paste special then click on Excel link.
Message 7 of 19
Crass
Where is the edit button you are talking about? Dos this make an AutoCAD editable table or OLE object?
AutoCAD 2018/2021
Message 8 of 19
pendean
Community Legend
Community Legend
EDIT pulldown menu: PASTESPEC is the command if you want to type it. It's just another option, a linked OLE object is the result.
Message 9 of 19
I think we are not on the same page. If I am not wrong, you want to extract some values from Excel tables directly into existing Autocad tables. I have not tried that because I don't like using the Table function in AutoCad since it is very slow and very limited in function. I do all my tables and calculations/programming in Excel and then I would just paste them onto Autocad. You can highlight/copy the range in Excel and then right click in Autocad and it will allow you to paste the excel file as a one autocad entity. The problem with this is that if you update the Excel file, the one pasted on Autocad will not be updated. However, if, after you higlight/copy a range in Excel, go to your Autocad drawing but instead of right clicking, click on the Edit pulldown menu then click on paste special then click on paste link. It does create an OLE and each time you update and save the Excel file it will automatically be reflected on the Autocad.
Message 10 of 19
Thanks, this worked perfectly for me.
Message 11 of 19
when i paste the table from excel to auto-cad , the color of the text is black and the text style inside the table is standard , how can i change it to any other text style without edit cell by cell ?
Message 12 of 19
pendean
Community Legend
Community Legend
What method of "pasting" did you do?
Message 13 of 19
I SELECTED ALL THE CELLS I WANT THEN I COPED IT IN TO AUTO-CAD AS WRITTEN . THE TEXT COLOR IS BLACK AS IN THE EXCEL SHEET , TO SOLVE IT I CHANGED THE TEXT COLOR IN EXCEL THE I COPED IT TO AUTO-CAD , IS THAT RIGHT ?
Message 14 of 19
The text appears black and cannot be changed all at once after pasting AutoCAD Entities. Is there a way to change it all at once to white?
I am unable to change all pasted cells to white, color 7, for some reason.
Please help?
Message 15 of 19
bleonard9YNE6
Community Visitor
Community Visitor
I'm having the same trouble - Copy from Excel>Paste Special>ACAD Entities
The text color comes in as black 0,0,0 and does not correlate with the standard white (7) in my layer. To change the color, I have to change it via Text Edit by changing the text in each individual cell to By Layer (white). This is very time consuming... Is there a work around?
Message 16 of 19
h_s_walker
Unfortunately not in LT. In full AutoCad I believe there is a workaround which sorts the table all at once.
Howard Walker
Left Handed and Proud
Message 17 of 19
cadffm
{ in full-AutoCAD i would use the tool STRIPMTEXT }
In LT i would change the color in Excel, of course it is still an internal truecolor mtext format,
but others way with a real solution is to much work or needs much knowledge how to edit
File content by workarounds (like ascii DXF or temporary inside another software)
Sebastian
Message 18 of 19
saqib2s
Community Visitor
Community Visitor
yes, it worked out well for me. Thank you Crass
Message 19 of 19
Claire_Bock
Community Visitor
Community Visitor
If you already have a table set up in AutoCAD and you are wanting to copy / paste a number of cells from Excel into your AutoCAD table, you could use the following steps:
  1. Select all the cells you are wanting to replace / fill in your AutoCAD table, then right-click and select Locking - Format Locked from the menu.
  2. Go to your Excel table and copy the text / cells you want to paste into your AutoCAD table.
  3. In AutoCAD, type 'PASTESPEC' in the Command bar and select Paste - AutoCAD Entities, and OK.
  4. Download the lisp file 'StripMtext v5-0b.lsp' from a search engine.
  5. Save the lisp file to your local drive and then drag-and-drop into your AutoCAD drawing.
  6. Type 'STRIPMTEXT' into the Command bar, draw a lasso around the pasted table (AutoCAD Entities) that you pasted in your AutoCAD drawing from Excel, check all boxes (Select All) in the pop-up window, and press OK.
  7. Select all the cells in your pasted table (AutoCAD Entities) and press Ctrl + C, then click in the first cell of your AutoCAD table (where you want the data to paste) and press Ctrl + P.
